Introduction
Use this guide to remove or replace the Lightning connector assembly for the iPhone SE 2022. This assembly includes the lower microphones, an antenna converter cable, and the Lightning connector. If you've tried cleaning the lightning port to no avail, replacing the Lightning connector can solve charging and connectivity issues.
This guide was performed on the A2783 (international) model.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ce dont vous avez besoin
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the right edge of the phone.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Power off your phone before beginning disassembly.
Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Outil utilisé dans cette étape :Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel, not the screen itself.
Skip the next two steps.
It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Slide the opening pick to the bottom right corner to slice the front panel adhesive.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
Stop near the top left corner of the display.
Remove the opening picks.
Gently pull up on the suction handle to lift up the bottom edge of the display.
Remove the suction handle.
Slide an opening pick underneath the top left corner of the display.
Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
Open the phone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Remove the four Phillips screws securing the lower display cable bracket:
Two 1.2 mm-long screws
Two 2.8 mm-long screws
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers to carefully remove the lower display cable bracket.
Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
Use a pair of tweezers to carefully remove the front sensor assembly bracket.
Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
Unfasten the three screws securing the Lighting connector bracket:
One 1.2 mm-long Y000 screw
One 2.7 mm-long Phillips screw
One 2.9 mm-long Phillips screws
Use a pair of tweezers to remove the Lightning connector bracket.
Carefully slide an opening pick between the antenna flex cable and the top of the speaker.
Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna by prying its connector straight up from its socket.
Use a pair of tweezers to remove the Wi-Fi diversity antenna.
Outil utilisé dans cette étape :Standoff Screwdriver for iPhones$5.49
Remove the two screws securing the Taptic Engine:
One 2.1 mm Phillips screw
One 2.1 mm standoff screw
Use a pair of tweezers to remove the grounding bracket at the left edge of the Taptic Engine.
Use the pointed end of your spudger to pry the antenna cable socket up and away from the Taptic Engine connector below.
Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
Use a pair of tweezers to carefully remove the Taptic Engine.
Note that the grounding connector on the Taptic Engine's left side goes under the fixed contact, you'll need to remember than when reassembling.
Remove the two screws securing the barometric vent:
One 1.9 mm-long Phillips screw
One 1.7 mm-long Phillips screw
Use a pair of tweezers to remove the barometric vent.
Use the pointed end of a spudger to disconnect the rear camera by prying the connector straight up from its socket.
Remove the two screws securing the rear-facing camera bracket:
One 3.0 mm-long standoff screw
One 3.1 mm-long Phillips screw
Use a pair of tweezers to remove the rear camera bracket.
Use the pointed end of a spudger to disconnect the flash by prying the connector straight up from its socket.
Remove the two screws securing the upper cable bracket:
One 2.8 mm-long Phillips screw
One 1.2 mm-long Phillips screw
Use a pair of tweezers to remove the upper cable bracket.
Use the pointed end of a spudger to disconnect the upper flex cable by prying the connector straight up from its socket.
Unfasten the three 1.2 mm-long Phillips screws securing the top left antenna component.
Use a pair of tweezers to remove the top left antenna component.
Unfasten the two screws securing the top left grounding bracket:
One 1.5 mm-long Phillips screw
Use a pair of tweezers to remove the top left grounding bracket.
Unfasten the four screws securing the logic board:
One partially threaded 1.7 mm-long Phillips screw
One 2.5 mm-long standoff screw
One 2.2 mm-long standoff screw
Use a pair of tweezers to carefully pry up the logic board grounding bracket in the top right corner of the rear case.
Use the pointed end of a spudger to move the SIM card eject plunger out of the logic board's way by pushing it to the right edge of the rear case.
Use the pointed end of a spudger to disconnect the Lightning port cable by prying the connector straight up from its socket.
Use the pointed end of a spudger to disconnect the wireless charging coil cable by prying the connector straight up from its socket.
Use the flat end of a spudger to gently pry up the battery connector end of the logic board.
Grasping it by the edges, lift the logic board near the battery connector and remove it.
Unfasten the two screws securing the loudspeaker:
One 1.4 mm-long Phillips screw
One 2.1 mm-long Phillips screw
Use a pair of tweezers to remove the loudspeaker.
Unfasten the five screws securing the lighting connector to the rear case:
One 1.3 mm-long Phillips screw
Two 2.3 mm-long Phillips screws
Two 1.4 mm-long Phillips screws
Use the pointed end of a spudger to gently pry the two microphones on the left and right of the Lightning connector free from the adhesive securing them in place.
Apply a heated iOpener to the bottom of the rear case to loosen the charging port assembly adhesive, angling it as shown.
Slide an opening pick underneath the top portion of the Lightning connector assembly flex cable, and begin separating the cable from the rear case.
Continue separating the upper portion of the flex cable, being careful not to damage any other components along the way.
Stop sliding the pick once it passes the lower edge of the battery.
Remove the Lightning connector assembly.
Remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Compare your new replacement part to the original part—you may need to transfer other remaining components or remove additional adhesive backings from the new part before installing.
7 autres ont terminé cette réparation.
Un commentaire
After doing this my loudspeaker has static. Anyone else experience this?
