Aller au contenu principal
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
20 questions Voir tout
Why isn't my flash working?
Even in the darkness, my flash isn't functioning to make bright photos. I have the settings how they should be, but nothing is helping. What could be the problem?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
  • The flash is not turned on. Turn the flash setting on. There is typically a manual setting.
  • The bulb is burned out. A replacement is needed.
  • The wires between the battery source and flash may be disconnected. They must be reconnected.
Indice 0
There could be a couple of different reasons. Most likely, it's an issue with the settings on your camera. On the top dial, turn it to an automatic setting so the camera will do the focusing for you. If that doesn't work, it could be an internal issue that will require replacement or repair.
Indice 0
Ajouter une réponse
Nathan Meuwissen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 483
