Aller au contenu principal
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 questions Voir tout
My 3ds won't charge anymore
My 3ds won't charge the battery, I've tried multiple chargers and a docking to try it, but notting works. I think it has something to do with the charge port but I am not sure.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
I also had this problem. It is fixed now. In my case, it was a problem with the outlet box (the part that connects with the outlet). The problem was that a wire had disconnected from the plug in part (sorry I don’t know what parts are called). I hope this could be helpful. Just a reminder to check all parts of the situation before sending your device in.
par
Ajouter un commentaire
1 Réponse
Solution retenue
@dpesser , David, could be a faulty charge port, first check for dust debri and blow it out, also look inside to see if contacts are bent and straighten with a pin if bent. Could also be a faulty battery if older consider replacing it.Links below for trouble shooting and replacing charge port and a link to charge port and battery for 3DS. Good luck.
https://www.youtube.com/watch?v=oZrprlK7...
https://www.youtube.com/watch?v=0_8XEsi-...
https://www.amazon.com/Socket-Connector-...
Indice 4
1 commentaire:
Thanks for the response, I will try it out.
par
Ajouter une réponse
David sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 59
Total : 35,752
