Aller au contenu principal
Processeur: Pentium M 1.6 GHz, RAM: 512 MB Stockage: 40 GB HDD
16 questions Voir tout
Why can't I turn on the laptop?
I've been unable to power up the laptop. Not sure why, but I do know someone turned off the power to my AC adapter (my battery died a few months ago, so I don't use one) and I haven't been able to turn on the laptop ever since.
When I connect the power cable to the laptop, the power symbol (the two-pin head icon) lights up. However, when I press the power button, nothing happens and the two-pin head icon goes out. If I remove the power cable and plug it back in, the symbol lights up again.
Anyone think they can help?
Répondre à cette question J'ai le même problème
Indice 2
2 commentaires
Were you able to resolve your problem? I am having the exact same issue. Thanks.
par
momocha, that question has not been answered since Nov 2010. You get better help if you ask your own question, it is not difficult to do and anybody will se you asked for help. Good Luck
par
Ajouter un commentaire
5 Réponses
Réponse la plus utile
Try unplugging the laptop (normally you'd remove the battery also, but you've got that covered!) and holding down the power button for a good 10 seconds, then plugging it back in and turning it on. I've straightened out several Thinkpad / Lenovos that way when they exhibit the symptoms you describe.
Indice 1
Could be a RAM issue. On this model I believe that there is one stick on the bottom and one underneath the keyboard. Try removing one at a time to see if either might be causing the problem.
Indice 1
Same Problem i had back then with another Laptop. It was some dried-out condensers in the near area of the power jack.
Indice 0
your laptop had a Short circuit!
Indice 0
I got my IBM X31 fixed with the same issue. Turns out to be that the connections on the port needing bending back into shape and spraying with switch lubricant. Now it works fine.
Try applying pressure on the power connector to see if power comes on intermittently. If so, it might be the same issue as mine.
Indice -1
Ajouter une réponse
Jonah Sun sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 7,146
