Aller au contenu principal
La DualShock 4 CUH-ZCT2 a été annoncée en 2016 pour remplacer la manette PS4 CUH-ZCT1 sortie en 2013. Cette manette est similaire au modèle précédent.
20 questions Voir tout
Control doesn't turn on
The control does not react, doesn't work with the cable connected to the console
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Your cable may not be working properly, in which case, you should check to see if it has any physical damage. You may have to buy a new cable.
However, this could also be a battery issue. You may have to replace the battery. iFixit has a device guide that will instruct you on how to do so.
Another issue could be that your controller isn't charging properly. As I mentioned earlier, this could be an issue with the cable. However, it could also be an issue with the charging port. iFixit also has a device guide that will instruct you on how to replace your controller's charging port.
Indice 1
1 commentaire:
my controller is on and virating not letting me do anything
par
I had a similar problem, my DS4 wasn't turning on, even though it was charging normally.
when I opened it I found that the (I think it is called) Ribbon Circuit Board ( a thin layer with many connection lines ) was broken on the like that connects the PS button, I order a new one online and replaced it and it worked perfectly.
Indice 0
Ajouter une réponse
Jocsan SV sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 1,237
