Aller au contenu principal
2005 Jeep Liberty Fog Light Replacement
Ce dont vous avez besoin
  1. 2005 Jeep Liberty Fog Light Replacement, Fog Light: étape 1, image 1 de 1
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. 2005 Jeep Liberty Fog Light Replacement: étape 2, image 1 de 1
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. 2005 Jeep Liberty Fog Light Replacement: étape 3, image 1 de 1
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. 2005 Jeep Liberty Fog Light Replacement: étape 4, image 1 de 1
    • Lift up on the tension screw to release the light housing.
  5. 2005 Jeep Liberty Fog Light Replacement: étape 5, image 1 de 1
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. 2005 Jeep Liberty Fog Light Replacement: étape 6, image 1 de 1
    • Pull the light housing toward you.
  7. 2005 Jeep Liberty Fog Light Replacement: étape 7, image 1 de 1
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. 2005 Jeep Liberty Fog Light Replacement: étape 8, image 1 de 1
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. 2005 Jeep Liberty Fog Light Replacement: étape 9, image 1 de 1
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
CHARLES CATLEDGE
Membre depuis le 09/17/17
161 Réputation
1 tutoriel rédigé
Équipe
Pasco Hernando, Team S4-G55, Prince Winter 2017 Membre de l'équipe Pasco Hernando, Team S4-G55, Prince Winter 2017
PHSC-PRINCE-W17S4G55
1 membre
1 tutoriel rédigé
2 commentaires
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 32
Total : 7,040
