Aller au contenu principal
2015 Jeep Patriot Tail/ Brake Light Replacement
Yadira Vera
Yadira Vera et 5 autres contributeurs
Dernière mise à jour le June 8, 2023
20 - 40 minutes
Modérée
A besoin de meilleures images
Étapes manquantes
To ensure the safety of drivers, it is important to have functioning brake lights. If the brake lights on your 2015 Jeep Patriot aren't illuminating and need to be replaced, use this guide to replace the lightbulb.
The purpose of a tail/ brake light is to make your car visible during nighttime and heavy weather conditions and to communicate to the driver behind you that you are slowing down or stopping. A broken tail/ brake light is dangerous to yourself and the drivers around you. You could also get pulled over and receive a citation if your tail light is out.
Before beginning the repair, park in a safe location, turn the car off and put the emergency brake on.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: étape 1, image 1 de 2 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: étape 1, image 2 de 2
    • Open the trunk and locate the fender clips.
    • These are located near the tail lights.
  2. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 2, image 1 de 3 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 2, image 2 de 3 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 2, image 3 de 3
    • Use the 3/16 inch flathead screwdriver to remove the top fender clip holding the tail light on.
  3. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 3, image 1 de 1
    • Remove the lower fender clip.
    • This will release the tail light so be careful.
  4. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 4, image 1 de 2 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 4, image 2 de 2
    • Remove the tail light to expose the light bulb.
  5. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 5, image 1 de 2 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 5, image 2 de 2
    • Twist the light bulb to remove it from the holder.
    • Replace the old bulb with the new one. make sure to twist the new bulb to secure it.
    • Do not touch the new light bulb with your bare hands as the oil from your fingers will cause it to degrade faster and possibly shatter.
  6. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 6, image 1 de 2 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 6, image 2 de 2
    • Align the two pegs on the tail light housing with the matching holes on the car.
  7. 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 7, image 1 de 2 2015 Jeep Patriot Tail/ Brake Light Replacement: étape 7, image 2 de 2
    • Reinsert the top and bottom fender clips.
Yadira Vera
Membre depuis le 10/26/22
145 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-7, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 1-7, Briggs Fall 2022
CSULA-BRIGGS-F22S1G7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 50
30 derniers jours : 115
Total : 3,611
