Aller au contenu principal
AEE Mach 1 Camera Replacement
Cameron C Blanchard
Cameron C Blanchard et 4 autres contributeurs
Dernière mise à jour le April 14, 2022
45 minutes - 1 heure
Modérée
A besoin de meilleures images
This IFIXIT guide allows you to safely and properly remove the CAMERA from the AEE Mach 1 Drone. In order to remove the camera, please follow the step-by-step directions below and make sure to use the proper tools listed. When removing the top panel, make sure to be careful as there are still wired connections. Fix it!
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. AEE Mach 1 Camera Replacement, Camera: étape 1, image 1 de 1
    • Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
  2. AEE Mach 1 Camera Replacement: étape 2, image 1 de 2 AEE Mach 1 Camera Replacement: étape 2, image 2 de 2
    • Holding the base of a propeller with one hand, unscrew the propeller by hand in a clockwise direction. Complete this action on all 4 propellers.
  3. AEE Mach 1 Camera Replacement: étape 3, image 1 de 2 AEE Mach 1 Camera Replacement: étape 3, image 2 de 2
    • Flip the AEE Mach 1 upside down.
    • Remove the screws on the drone's arms using a Torx T5 screwdriver.
  4. AEE Mach 1 Camera Replacement: étape 4, image 1 de 2 AEE Mach 1 Camera Replacement: étape 4, image 2 de 2
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  5. AEE Mach 1 Camera Replacement: étape 5, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the screws from the four corners of the inner white chassis.
  6. AEE Mach 1 Camera Replacement: étape 6, image 1 de 2 AEE Mach 1 Camera Replacement: étape 6, image 2 de 2
    • Using a Spudger (or similar tool to scrap/pry with), remove the copper foil used as tape from the sides of the chassis.
    • Remove the small metal covering from the side boards.
    • This can be done by hand or with the assistance of a prying tool.
  7. AEE Mach 1 Camera Replacement: étape 7, image 1 de 2 AEE Mach 1 Camera Replacement: étape 7, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the four screws separating the side board from the white chassis.
  8. AEE Mach 1 Camera Replacement: étape 8, image 1 de 2 AEE Mach 1 Camera Replacement: étape 8, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the four screws from the large motherboard on the white chassis.
    • Lift the motherboard out of the case, revealing the camera cable.
  9. AEE Mach 1 Camera Replacement: étape 9, image 1 de 3 AEE Mach 1 Camera Replacement: étape 9, image 2 de 3 AEE Mach 1 Camera Replacement: étape 9, image 3 de 3
    • Using the Phillips #00 screwdriver, remove the four screws holding the camera mechanism in place.
    • Lift the camera assembly out of the case.
Cameron C Blanchard
Membre depuis le 09/16/20
524 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 385
