Aller au contenu principal
ASUS PadFone X Station Power and Volume Contacts Replacement
Jessica
Jessica et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
5 - 10 minutes
Facile
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: étape 1, image 1 de 2 ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: étape 1, image 2 de 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Power and Volume Contacts Replacement, Locate CON1501: étape 2, image 1 de 1
    • Locate CON1501
    • CON1501 will be visible underneath the contacts. You can readily see this if you look for the orange strip of film in the top right corner of the back of the Asus Padfone X Docking Station.
  3. ASUS PadFone X Station Power and Volume Contacts Replacement, Remove (1) phillips screw.: étape 3, image 1 de 1
    • Remove (1) phillips screw
    • Using a +PH00 Phillips screwdriver , you will unscrew the Phillips screw in the top right corner of the back of the ASUS Padfone X docking station.
    • To unscrew the Phillips screw simply position the screwdriver inside of the screw, then rotate it counter-clockwise until the screw is fully removed from the docking station.
  4. ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: étape 4, image 1 de 2 ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect ribbon from CON1510
    • To disconnect the ribbon from CON1510, use a pair of tweezers and gently lift the connect up and back from the device.
  5. ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: étape 5, image 1 de 3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: étape 5, image 2 de 3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: étape 5, image 3 de 3
    • Now that the contacts are no longer attached, you can use either tweezers or your fingers to grasp and lift contacts vertically off of the device.
2 autres ont terminé cette réparation.
Jessica
Membre depuis le 10/07/14
150 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 7-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 573
