Aller au contenu principal
Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement
Bailey Johnson
Bailey Johnson et un autre contributeur
Dernière mise à jour le May 16, 2022
15 - 20 minutes
Modérée
If your Acer Chromebook Spin 11 (Model R751TN-C5P3) is not producing a proper picture and you have reason to believe that the LCD panel or cable could be the root of the problem, then use this guide to replace the assembly.
The LCD cable connects to the power source and the LCD screen to provide the picture that appears on the screen of the device. A Faulty LCD cable will not produce a proper picture or may not even produce a picture at all.
Prior to using this guide, ensure that nothing is pinching the cable when you remove the back plating from the cable. A pinched cable may not be completely faulty but may just need to be freed from whatever the source is that is hindering its productivity.
Before beginning, ensure that the device is powered off completely in order to avoid damaging the device further, or causing any personal harm.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: étape 1, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, LCD Screen & Digitizer Assembly: étape 1, image 2 de 2
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 2, image 1 de 1
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 3, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 3, image 2 de 2
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 4, image 1 de 1
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 5, image 1 de 1
    • Unravel the cord from around the screen and lift up on the screen to remove.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement, Display Assembly: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove all twelve 6 mm screws in the bottom panel of the Chromebook.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 7, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 7, image 2 de 2
    • Use an opening tool to pry open the Chromebook casing starting from the corners.
  8. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 8, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the 6 mm hinge screws on the right side of the Chromebook.
  9. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 9, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 9, image 2 de 2
    • Disconnect the end of LCD cable that is connected to the motherboard. Lift the connector's ZIF tab and gently pull the ribbon cable free.
    • Disconnect the other end of the LCD cord from the left side of the motherboard.
  10. Acer Chromebook Spin 11 R751TN-C5P3 Display Assembly Replacement: étape 10, image 1 de 1
    • The LCD cable has been disconnected and can be removed by guiding it out of the hooks that keeps it in placed.
Bailey Johnson
Membre depuis le 03/21/22
691 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 592
