Aller au contenu principal
Acer Chromebook cb3-532-c47c LED Board Replacement
Jerry Wheeler
Jerry Wheeler et un autre contributeur
Dernière mise à jour le July 1, 2022
Aucune estimation
Facile
Tutoriel réalisé par la communauté
The LED board has one purpose, to hold the two LEDs visible from the front of the computer. Issues with the LED board itself are extremely rare.
Ce dont vous avez besoin
Outils
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: étape 1, image 1 de 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: étape 1, image 2 de 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: étape 2, image 1 de 2 Acer Chromebook cb3-532-c47c LED Board Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: étape 3, image 1 de 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: étape 4, image 1 de 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: étape 4, image 2 de 2
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: étape 5, image 1 de 2 Acer Chromebook cb3-532-c47c LED Board Replacement: étape 5, image 2 de 2
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: étape 6, image 1 de 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: étape 6, image 2 de 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: étape 6, image 3 de 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Jerry Wheeler
Membre depuis le 03/21/22
72 055 Réputation
71 tutoriels rédigés
Équipe
Oregonians Membre de l'équipe Oregonians
Community
8 membres
189 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 87
