Aller au contenu principal
Acer Iconia One 7 Rear-Facing Camera Replacement
Michael
Michael et 7 autres contributeurs
Dernière mise à jour le May 7, 2024
Aucune estimation
Modérée
The rear facing camera is utilized when taking pictures in front of the device. In this case it is separated from the front facing camera and works separately as well. Pieces regarding this camera are significantly small so be aware of any missing items.
Ce dont vous avez besoin
Outils
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: étape 1, image 1 de 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: étape 3, image 1 de 1
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: étape 4, image 1 de 2 Acer Iconia One 7 Rear-Facing Camera Replacement: étape 4, image 2 de 2
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: étape 5, image 1 de 2 Acer Iconia One 7 Rear-Facing Camera Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Michael
Membre depuis le 09/03/15
519 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 membres
5 tutoriels rédigés
Un commentaire
How to get new camera if the original camera is damaged
Prakash Hasabnis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 21
Total : 469
