Acer Iconia Tab A501 Display Replacement
Introduction
Passez à l'étape 1A display shows you what is happening on your device. Without a working display, a device isn’t much use. This guide will show you how to replace the display on your Acer Iconia Tab A501.
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
Outil utilisé dans cette étape :Tweezers$3.99
Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Use the Halberd Spudger to carefully pop up and take out the ports.
