Aller au contenu principal
Acer Nitro 5 AN515-55-53AG Internal Fan Replacement
Jordin Hill
Jordin Hill et 5 autres contributeurs
Dernière mise à jour le March 4, 2024
20 - 30 minutes
Modérée
Photos d’action
A besoin de meilleures images
The fans inside the Acer Nitro 5 AN515-55-53AG laptop can occasionally get stuck, dusty, or fail completely. Fans are essential to the operation of a graphics card (GPU) or central processor (CPU). They help keep the graphics card operating at a low temperature. The GPU will quickly overheat and shut down if the fans are removed or malfunction. Fixing this is often a matter of some small handiwork to get inside the computer and check the fans for what might be sticking. Use this guide to access the internal GPU/CPU cooling fan. From here, it is possible to unjam, clean, or replace the fan as needed.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement, Fan: étape 1, image 1 de 1
    • Prior to beginning, be sure to turn off the device and unplug it from the power source.
    • Set the device on a flat surface with the vents facing upwards.
  2. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 2, image 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 2, image 2 de 2
    • Use your Phillips #0 screwdriver to remove the eleven screws holding down the laptop's bottom cover.
  3. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 3, image 1 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 3, image 2 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Remove the laptop's bottom cover using an opening tool or plastic card.
    • Do not use a metal tool during this process. Doing so would risk damaging both the cover and the electrical components.
    • Be gentle during removal. Do not force the cover off, or it may break.
  4. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 4, image 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 4, image 2 de 2
    • Detach the fan's wire connector from the motherboard.
  5. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 5, image 1 de 1
    • Peel up the two strips of black tape holding the fan.
    • Do not peel the tape all the way off. Leave the tape attached to the heatsink.
  6. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 6, image 1 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 6, image 2 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 6, image 3 de 3
    • Remove the two screws holding the fan in place using a Phillips #0 screwdriver.
    • Remove the old fan by pulling it directly up.
  7. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 7, image 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: étape 7, image 2 de 2
    • While the fan is out, clean the space with a cloth or a can of compressed air. Clean the fan vents and plate of any dust.
2 autres ont terminé cette réparation.
Un commentaire
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
Антон Хабаров - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 100
Total : 6,111
