Aller au contenu principal
Acer Spin 5 SP515-51GN-807G Battery Replacement
James Wasielewski
James Wasielewski et 5 autres contributeurs
Dernière mise à jour le February 14, 2025
10 - 15 minutes
Facile
Tutoriel étudiant vedette
If your Acer Spin 5 SP515-51GN-807G laptop is failing to power on or you are experiencing symptoms of an old battery such as faster than normal discharge, use this guide to replace the battery.
It is important to have a healthy, functioning battery to ensure your laptop runs efficiently. If you notice after a long period of time that your laptop battery is draining faster than normal, you may want to consider replacing the battery.
When replacing a battery it is important to take several precautions. Make sure to avoid puncturing the battery, as that can cause a fire. Also, make sure to take appropriate precautions with a swollen battery. Always remember to power down the device before beginning replacement.
After replacement, please make sure to follow proper procedures when disposing of the battery.
Ce dont vous avez besoin
Kit de réparation
Ce kit contient toutes les pièces et tous les outils nécessaires à la réalisation de ce tutoriel.
Pièces
Outils
Afficher plus…
  1. Acer Spin 5 SP515-51GN-807G Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 2, image 1 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 2, image 2 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 3, image 1 de 1
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: étape 4, image 1 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: étape 4, image 2 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 5, image 1 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 5, image 2 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 5, image 3 de 3
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 6, image 1 de 2 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 6, image 2 de 2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 7, image 1 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 7, image 2 de 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 7, image 3 de 3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 8, image 1 de 2 Acer Spin 5 SP515-51GN-807G Battery Replacement: étape 8, image 2 de 2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 65
Total : 2,052
