Aller au contenu principal
Afridev Casing Pipe Disassembly
Jake Devincenzi
Jake Devincenzi et 5 autres contributeurs
Dernière mise à jour le July 16, 2019
Aucune estimation
Difficile
Use this guide to lift the casing pipe of an Afridev pump out of the pump in order to repair a broken or damaged segment of the pipe.
  1. Afridev Casing Pipe Disassembly, Head: étape 1, image 1 de 2 Afridev Casing Pipe Disassembly, Head: étape 1, image 2 de 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Casing Pipe Disassembly: étape 2, image 1 de 3 Afridev Casing Pipe Disassembly: étape 2, image 2 de 3 Afridev Casing Pipe Disassembly: étape 2, image 3 de 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Casing Pipe Disassembly: étape 3, image 1 de 2 Afridev Casing Pipe Disassembly: étape 3, image 2 de 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Casing Pipe Disassembly, Axle and Handle: étape 4, image 1 de 3 Afridev Casing Pipe Disassembly, Axle and Handle: étape 4, image 2 de 3 Afridev Casing Pipe Disassembly, Axle and Handle: étape 4, image 3 de 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Casing Pipe Disassembly: étape 5, image 1 de 2 Afridev Casing Pipe Disassembly: étape 5, image 2 de 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Casing Pipe Disassembly: étape 6, image 1 de 3 Afridev Casing Pipe Disassembly: étape 6, image 2 de 3 Afridev Casing Pipe Disassembly: étape 6, image 3 de 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Casing Pipe Disassembly: étape 7, image 1 de 2 Afridev Casing Pipe Disassembly: étape 7, image 2 de 2
    • Lift the handle to a horizontal position.
  8. Afridev Casing Pipe Disassembly: étape 8, image 1 de 3 Afridev Casing Pipe Disassembly: étape 8, image 2 de 3 Afridev Casing Pipe Disassembly: étape 8, image 3 de 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Casing Pipe Disassembly: étape 9, image 1 de 3 Afridev Casing Pipe Disassembly: étape 9, image 2 de 3 Afridev Casing Pipe Disassembly: étape 9, image 3 de 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Casing Pipe Disassembly: étape 10, image 1 de 2 Afridev Casing Pipe Disassembly: étape 10, image 2 de 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Casing Pipe Disassembly, Pump Rod: étape 11, image 1 de 2 Afridev Casing Pipe Disassembly, Pump Rod: étape 11, image 2 de 2
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Casing Pipe Disassembly: étape 12, image 1 de 2 Afridev Casing Pipe Disassembly: étape 12, image 2 de 2
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Casing Pipe Disassembly: étape 13, image 1 de 3 Afridev Casing Pipe Disassembly: étape 13, image 2 de 3 Afridev Casing Pipe Disassembly: étape 13, image 3 de 3
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Casing Pipe Disassembly: étape 14, image 1 de 3 Afridev Casing Pipe Disassembly: étape 14, image 2 de 3 Afridev Casing Pipe Disassembly: étape 14, image 3 de 3
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
  15. Afridev Casing Pipe Disassembly, Tank: étape 15, image 1 de 2 Afridev Casing Pipe Disassembly, Tank: étape 15, image 2 de 2
    • Place one wrench on the top side of the top base of the tank spout.
    • Place another wrench on the underside of the bolt in order to get more leverage.
    • Pull the top wrench to the right, and the bottom wrench to the left.
  16. Afridev Casing Pipe Disassembly: étape 16, image 1 de 3 Afridev Casing Pipe Disassembly: étape 16, image 2 de 3 Afridev Casing Pipe Disassembly: étape 16, image 3 de 3
    • Remove the loosened bolt from the pump.
    • Repeat this procedure for the 3 remaining bolts.
  17. Afridev Casing Pipe Disassembly: étape 17, image 1 de 2 Afridev Casing Pipe Disassembly: étape 17, image 2 de 2
    • Lift the tank straight up to remove it from the pump.
    • Be sure to place the tank in a sanitary place to prevent contamination.
  18. Afridev Casing Pipe Disassembly, Afridev Casing Pipe Disassembly: étape 18, image 1 de 2 Afridev Casing Pipe Disassembly, Afridev Casing Pipe Disassembly: étape 18, image 2 de 2
    • Slightly twist the head flange until the corners overhang the top of the tank, far enough so that you can grab them.
  19. Afridev Casing Pipe Disassembly: étape 19, image 1 de 3 Afridev Casing Pipe Disassembly: étape 19, image 2 de 3 Afridev Casing Pipe Disassembly: étape 19, image 3 de 3
    • Lift the top plate to expose the casing pipe.
    • Place a piece of wood or brick underneath the top plate to hold it in place.
  20. Afridev Casing Pipe Disassembly: étape 20, image 1 de 3 Afridev Casing Pipe Disassembly: étape 20, image 2 de 3 Afridev Casing Pipe Disassembly: étape 20, image 3 de 3
    • Untie knots from the flange, holding on to the loose ends of the rope.
  21. Afridev Casing Pipe Disassembly: étape 21, image 1 de 2 Afridev Casing Pipe Disassembly: étape 21, image 2 de 2
    • With two people holding each end of the rope, remove the support underneath the top plate and lower the plate.
    • This may require a bit of force, since the plate may be attached tightly.
  22. Afridev Casing Pipe Disassembly: étape 22, image 1 de 3 Afridev Casing Pipe Disassembly: étape 22, image 2 de 3 Afridev Casing Pipe Disassembly: étape 22, image 3 de 3
    • Lift the casing from the borehole, simultaneously pulling up on the ropes to support the casing.
  23. Afridev Casing Pipe Disassembly: étape 23, image 1 de 3 Afridev Casing Pipe Disassembly: étape 23, image 2 de 3 Afridev Casing Pipe Disassembly: étape 23, image 3 de 3
    • Slip a casing support over the casing.
  24. Afridev Casing Pipe Disassembly: étape 24, image 1 de 3 Afridev Casing Pipe Disassembly: étape 24, image 2 de 3 Afridev Casing Pipe Disassembly: étape 24, image 3 de 3
    • Continue lifting the casing, supporting the top portion with the casing support, as needed.
  25. Afridev Casing Pipe Disassembly: étape 25, image 1 de 3 Afridev Casing Pipe Disassembly: étape 25, image 2 de 3 Afridev Casing Pipe Disassembly: étape 25, image 3 de 3
    • When you reach the portion of the casing that needs to be repaired, tie the casing support ropes onto the frame.
  26. Afridev Casing Pipe Disassembly: étape 26, image 1 de 2 Afridev Casing Pipe Disassembly: étape 26, image 2 de 2
    • While supporting the casing, make the necessary repairs to the casing pipe.
Jake Devincenzi
Membre depuis le 04/18/11
118 226 Réputation
57 tutoriels rédigés
1 commentaire de tutoriel
It is much easier to lift the riser pipe AFTER you removed the foot valve. Removal of the foot valve requires use of the foot valve fish tool, being attached to the original rods (without using the piston and rod) and carefully lowered into the riser main. When it reaches bottom, turn it up to about 90 degree and see if it drops any during that turn. Then pull up sharply to remove the foot valve from its seat, and proceed with removing all the rods, fish tool and foot valve. When the foot valve comes off the seat, you may hear water running down the riser pipe, this is not a problem. That water was just being held above static water level by the working foot valve.
Larry Bentley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 454
