Aller au contenu principal
Amazon Echo Show 8 3rd Gen Volume Buttons Replacement
Venkat Reddy Kammala
Venkat Reddy Kammala et 3 autres contributeurs
Dernière mise à jour le December 26, 2024
45 - 50 minutes
Facile
The volume buttons on your Echo Show help you control how loud Alexa and your music plays, so if any of those buttons are not working properly, try restarting your Echo Show first. If it still doesn't work, then it's possible your volume button board is damaged. Follow these instructions to see how you can replace it.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: étape 1, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: étape 1, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: étape 1, image 3 de 3
    • Use a prying tool to remove the rubber foot at the bottom.
    • It is secured with adhesive and will lift off with some gentle prying.
    • Use an opening pick to remove the screw cover.
  2. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 2, image 1 de 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 2, image 2 de 2
    • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
  3. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 3, image 1 de 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 3, image 2 de 2
    • Insert a jimmy in the gap between the display and chassis.
    • Pry around the perimeter until the back case releases.
    • Be careful as to not damage the ribbon cable on the top left area of the screen.
    • Remove the back case.
  4. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 4, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 4, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 4, image 3 de 3
    • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
    • Carefully lift the board without straining the ribbon cable.
    • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
    • Disconnect the ribbon cable.
  5. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: étape 5, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: étape 5, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: étape 5, image 3 de 3
    • Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
    • Don't tilt the cable too much as you can damage the ribbon or the connector.
  6. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 6, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 6, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 6, image 3 de 3
    • Use a TR6 screwdriver to remove the six 7mm screws located around the speaker assembly.
    • Gently tilt the speaker assembly towards the ribbon cable.
    • The ribbon cable is fragile and can be damaged if moved any other way.
    • Flip open the black tab on the connector towards the cable and gently pull.
    • Don't use too much force pulling up on the tab, as it can break and the cable will no longer be properly connected.
  7. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 7, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 7, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 7, image 3 de 3
    • Use a TR6 Torx screwdriver to remove the eight 9 mm screws holding the metal bracket.
    • Gently lift off the metal bracket.
  8. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 8, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 8, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 8, image 3 de 3
    • Remove the 2 rubber stoppers.
    • Remove all 14 screws with a Phillips #1 screwdriver.
  9. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 9, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 9, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 9, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 1.3 cm screws holding down each driver.
    • Gently pull the plastic plate towards the antenna cable.
    • There is a small antenna cable that is easy to rip off the solder joint, so lift carefully.
    • There are 8 screws on the long side of the housing, but there is no driver behind it, so you don't need to remove them.
  10. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 10, image 1 de 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 10, image 2 de 2
    • Pry the speakers from the housing with a spudger.
    • The speakers are connected to a spring-loaded pin connector which is attached to the black plastic using industrial hot glue, so while you can heat the glue to remove it, the plastic may melt and/or deform, so we wouldn't recommend it.
  11. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: étape 11, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: étape 11, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: étape 11, image 3 de 3
    • Use an opening tool to flip up the black ZIF locking flap that secure the four ribbon cables.
  12. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 12, image 1 de 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 12, image 2 de 2
    • Use angled tweezers to disconnect all the ribbon cables from their motherboard sockets.
    • The ribbon cables are fragile; pull with care.
  13. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 13, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 13, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 13, image 3 de 3
    • Remove all 10 5 mm screws on the motherboard using a TR6 Torx screwdriver.
  14. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: étape 14, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: étape 14, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: étape 14, image 3 de 3
    • Remove the three 6 mm screws that secure the board using a TR4 Torx screwdriver.
  15. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 15, image 1 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 15, image 2 de 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: étape 15, image 3 de 3
    • Use an opening tool to flip open the black ZIF locking flap that secures the ribbon cable.
    • Be gentle with the ribbon cable.
    • Use tweezers to remove both buttons from the case.
Membre depuis le 08/28/24
589 Réputation
4 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 68
