Aller au contenu principal
Amazon Fire HD 10 Screen Replacement
Jaie Hillery
Jaie Hillery et 6 autres contributeurs
Dernière mise à jour le April 3, 2024
10 minutes
Modérée
Before you begin, make sure the device is off. The screen and digitizer will come off as one connected component.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 1 de 3 Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 2 de 3 Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 3 de 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: étape 2, image 1 de 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: étape 3, image 1 de 2 Amazon Fire HD 10 Screen Replacement: étape 3, image 2 de 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: étape 4, image 1 de 1
    • Remove the screen and digitizer from the case completely.
27 autres ont terminé cette réparation.
Jaie Hillery
Membre depuis le 10/07/14
1 757 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 membres
22 tutoriels rédigés
17 commentaires de tutoriel
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Réponse
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Réponse
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Réponse
What is needed to attach the screen back to the case?
Jimmy Lee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 34
30 derniers jours : 157
Total : 37,701
