Aller au contenu principal
AmazonBasics B0050BPWBQ On/Off Switch Replacement
Natalie Meert
Natalie Meert et un autre contributeur
Dernière mise à jour le April 22, 2022
10 minutes
Facile
The On/Off switch located on the front panel may become damaged and no longer function correctly. With a dysfunctional switch, you may not be able to get the shredder to operate.
Ce dont vous avez besoin
Outils
  1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: étape 1, image 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: étape 1, image 2 de 2
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: étape 2, image 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: étape 2, image 2 de 2
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: étape 3, image 1 de 1
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: étape 4, image 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: étape 4, image 2 de 2
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: étape 5, image 1 de 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: étape 5, image 2 de 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: étape 5, image 3 de 3
    • Pull the front panel away from the shredding unit.
    • Locate the black On/Off switch attached to the front panel where the control board was once attached.
    • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
Natalie Meert
Membre depuis le 02/11/16
678 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 2-4, Baechle Spring 2016 Membre de l'équipe IUPUI, Team 2-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G4
4 membres
8 tutoriels rédigés
Un commentaire
Does anyone know where to buy a replacement switch?
Shawn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 22
Total : 2,516
