Aller au contenu principal
Anker Soundcore 3 Microphone Replacement
Ce dont vous avez besoin
  1. Anker Soundcore 3 Microphone Replacement, Microphone: étape 1, image 1 de 2 Anker Soundcore 3 Microphone Replacement, Microphone: étape 1, image 2 de 2
    • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
    • Insert a metal spudger in between the speaker's front grill and chassis.
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Microphone Replacement: étape 2, image 1 de 3 Anker Soundcore 3 Microphone Replacement: étape 2, image 2 de 3 Anker Soundcore 3 Microphone Replacement: étape 2, image 3 de 3
    • Unscrew all 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
  3. Anker Soundcore 3 Microphone Replacement: étape 3, image 1 de 2 Anker Soundcore 3 Microphone Replacement: étape 3, image 2 de 2
    • Insert the metal spudger into the adhesive holding down the microphone.
    • Carefully pick away at the adhesive until you are able to gently remove the microphone with your hands.
Lucas_Jerina
Membre depuis le 08/28/24
269 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 33
