Aller au contenu principal
Anker Soundcore 3 Microphone Replacement
Lucas_Jerina
Lucas_Jerina et 2 autres contributeurs
Dernière mise à jour le December 18, 2024
15 - 25 minutes
Modérée
This is a replacement guide for the microphone on your Anker Soundcore 3. If you find that your microphone is being unresponsive fairly consistently, it may be time to replace it. Replacement of this device will require you to chip away at some glue holding certain components down, so please ensure that you are extremely careful as to not damage anything. This guide proves to only be at about a moderate difficulty so you shouldn't find too much trouble with this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Anker Soundcore 3 Microphone Replacement, Microphone: étape 1, image 1 de 2 Anker Soundcore 3 Microphone Replacement, Microphone: étape 1, image 2 de 2
    • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
    • Insert a metal spudger in between the speaker's front grill and chassis.
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Microphone Replacement: étape 2, image 1 de 3 Anker Soundcore 3 Microphone Replacement: étape 2, image 2 de 3 Anker Soundcore 3 Microphone Replacement: étape 2, image 3 de 3
    • Unscrew all 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
  3. Anker Soundcore 3 Microphone Replacement: étape 3, image 1 de 2 Anker Soundcore 3 Microphone Replacement: étape 3, image 2 de 2
    • Insert the metal spudger into the adhesive holding down the microphone.
    • Carefully pick away at the adhesive until you are able to gently remove the microphone with your hands.
Lucas_Jerina
Membre depuis le 08/28/24
269 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 47
