Aller au contenu principal
Apple Studio Display M2454 CCFL Inverter Replacement
Dylan Perry
Dylan Perry et 6 autres contributeurs
Dernière mise à jour le July 19, 2023
20 minutes
Facile
Conditions préalables manquantes
The CCFL Inverter is a vital part of the Apple Studio Display monitor and if it fails the monitor will have serious display problems. The CCFL inverter is what provides the backlight for the monitor. If it fails, the screen will essentially become black. This part, however, can be replaced with a new board relatively easily.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: étape 1, image 1 de 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: étape 1, image 2 de 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: étape 2, image 1 de 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: étape 3, image 1 de 2 Apple Studio Display M2454 CCFL Inverter Replacement: étape 3, image 2 de 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: étape 4, image 1 de 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: étape 5, image 1 de 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: étape 6, image 1 de 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Ligne d'arrivée
Dylan Perry
Membre depuis le 01/20/10
177 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-27, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 6,879
