Aller au contenu principal
Astro A20  Microphone Replacement
Jasmine Yarbrough
Jasmine Yarbrough et 2 autres contributeurs
Dernière mise à jour le May 30, 2022
10 - 15 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
The Astro A20 microphone replacement guide shows the steps of replacing a microphone with the use of a 60 mm extension, Phillips #1 screwdriver, and a new microphone.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Afficher plus…
  1. Astro A20  Microphone Replacement, Cushion: étape 1, image 1 de 1
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20  Microphone Replacement: étape 2, image 1 de 1
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20  Microphone Replacement: étape 3, image 1 de 2 Astro A20  Microphone Replacement: étape 3, image 2 de 2
    • Remove the ear cushion from the headset.
  4. Astro A20  Microphone Replacement, Microphone: étape 4, image 1 de 1
    • Place one hand on the back of the speaker.
  5. Astro A20  Microphone Replacement: étape 5, image 1 de 2 Astro A20  Microphone Replacement: étape 5, image 2 de 2
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20  Microphone Replacement: étape 6, image 1 de 2 Astro A20  Microphone Replacement: étape 6, image 2 de 2
    • Lift the speaker area.
    • Disconnect the wires that connect the microphone.
    • Remove the 7mm screw with a Phillips #1 screwdriver.
9 autres ont terminé cette réparation.
Jasmine Yarbrough
Membre depuis le 09/10/18
1 017 Réputation
5 tutoriels rédigés
Équipe
University of Alabama, Team S1-G2, Bedsole Fall 2018 Membre de l'équipe University of Alabama, Team S1-G2, Bedsole Fall 2018
UA-BEDSOLE-F18S1G2
4 membres
10 tutoriels rédigés
4 commentaires de tutoriel
worked for me….thanks
Thompson Crusher - Réponse
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Réponse
were? are you getting the new mic from? please link the site
jrod6t9 - Réponse
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 157
Total : 13,650
