Aller au contenu principal
Astro A40 TR Microphone Jack  Replacement
Christopher Beck
Christopher Beck et 3 autres contributeurs
Dernière mise à jour le May 31, 2022
15 - 20 minutes
Difficile
Outils incorrects
In this guide we will take you through replacing a faulty microphone jack of your Astro A40 TR.
If you want to be able to communicate with fellow gamers but your microphone is starting to intermittently lose sound or completely stopped working, then it may be time to replace your microphone jack. A microphone jack enables sound to transmit into the computer or other device.
In order to completely replace the speaker, step 5 contains instructions on how to solder and desolder connections.
Before you begin, make sure you have the proper tools needed.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Astro A40 TR Microphone Jack  Replacement, Speakers: étape 1, image 1 de 2 Astro A40 TR Microphone Jack  Replacement, Speakers: étape 1, image 2 de 2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Microphone Jack  Replacement: étape 2, image 1 de 3 Astro A40 TR Microphone Jack  Replacement: étape 2, image 2 de 3 Astro A40 TR Microphone Jack  Replacement: étape 2, image 3 de 3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Microphone Jack  Replacement: étape 3, image 1 de 2 Astro A40 TR Microphone Jack  Replacement: étape 3, image 2 de 2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Microphone Jack  Replacement: étape 4, image 1 de 2 Astro A40 TR Microphone Jack  Replacement: étape 4, image 2 de 2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Microphone Jack  Replacement: étape 5, image 1 de 1
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Microphone Jack  Replacement, Microphone Jack: étape 6, image 1 de 1
    • Remove the three screws in the photo with the J00 driver bit, and pull the headphone jack away from the assembly.
  7. Astro A40 TR Microphone Jack  Replacement: étape 7, image 1 de 1
    • Un-solder the two wires circled, at this point the entire assembly can be removed from the speaker and the remainder of the device.
Christopher Beck
Membre depuis le 10/20/16
164 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 6-5, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 41
Total : 9,141
