Aller au contenu principal
Asus 1015E-DS03 Front Screen Trim Replacement
Becca Day
Becca Day et 4 autres contributeurs
Dernière mise à jour le May 18, 2016
Aucune estimation
Modérée
This guide will show the user how to remove the front secret trim. The only tool needed is a spudger which will be used to push up the tabs connecting the screen to the base of the laptop.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Asus 1015E-DS03 Front Screen Trim Replacement, Battery: étape 1, image 1 de 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Front Screen Trim Replacement: étape 2, image 1 de 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Front Screen Trim Replacement: étape 3, image 1 de 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Front Screen Trim Replacement: étape 4, image 1 de 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Front Screen Trim Replacement, Front Screen Case: étape 5, image 1 de 1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Front Screen Trim Replacement: étape 6, image 1 de 2 Asus 1015E-DS03 Front Screen Trim Replacement: étape 6, image 2 de 2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Front Screen Trim Replacement: étape 7, image 1 de 1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
2 autres ont terminé cette réparation.
Becca Day
Membre depuis le 03/23/16
309 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 7-4, Benson Spring 2016 Membre de l'équipe Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 26
Total : 608
