Aller au contenu principal
Asus Eee PC 1005HA Keyboard Replacement
Chris Beichler
Chris Beichler et 14 autres contributeurs
Dernière mise à jour le December 15, 2022
10 - 15 minutes
Modérée
Use this guide to replace the keyboard in the Asus Eee PC 1005HA.
Ce dont vous avez besoin
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: étape 2, image 1 de 3 Asus Eee PC 1005HA Keyboard Replacement: étape 2, image 2 de 3 Asus Eee PC 1005HA Keyboard Replacement: étape 2, image 3 de 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: étape 4, image 1 de 3 Asus Eee PC 1005HA Keyboard Replacement: étape 4, image 2 de 3 Asus Eee PC 1005HA Keyboard Replacement: étape 4, image 3 de 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: étape 5, image 1 de 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
12 autres ont terminé cette réparation.
Chris Beichler
Membre depuis le 01/20/12
585 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-22, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 23,582
