Aller au contenu principal
Asus Transformer Book T100TAR Front Camera Replacement
Alyssa Ballesteros
Alyssa Ballesteros et un autre contributeur
Dernière mise à jour le December 19, 2016
10 - 15 minutes
Facile
If the front-facing camera on your laptop is broken, this guide will teach you step-by-step on how to disassemble your laptop and replace the camera.
Ce dont vous avez besoin
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: étape 1, image 1 de 2 Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: étape 1, image 2 de 2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Front Camera Replacement: étape 2, image 1 de 1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the spudger along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Front Camera Replacement: étape 3, image 1 de 1
    • Take off the rear case
  4. Asus Transformer Book T100TAR Front Camera Replacement: étape 4, image 1 de 1
    • Unscrew two 5mm screws from the camera board using a Phillips #0 Screwdriver.
  5. Asus Transformer Book T100TAR Front Camera Replacement: étape 5, image 1 de 1
    • Using a plastic opening tool, lift the white tab holding the power button cable, located on the camera board and pull out the cable strip.
  6. Asus Transformer Book T100TAR Front Camera Replacement: étape 6, image 1 de 1
    • Also using the plastic opening tool, gently lift up and remove the large black strip connecting the camera board to the motherboard.
  7. Asus Transformer Book T100TAR Front Camera Replacement: étape 7, image 1 de 1
    • Remove the camera board.
Alyssa Ballesteros
Membre depuis le 09/07/16
683 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 6-1, Remmell Fall 2016 Membre de l'équipe USF Tampa, Team 6-1, Remmell Fall 2016
USFT-REMMELL-F16S6G1
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 463
