Aller au contenu principal
Asus U56E Laptop Screen Replacement
David Zilar
David Zilar et 4 autres contributeurs
Dernière mise à jour le June 27, 2017
25 minutes
Modérée
Laptops are great, but sometimes things go wrong. This guide will teach you how to replace the screen on an Asus U56E laptop, and keep it working for years to come.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Asus U56E Laptop Screen Replacement, Screen: étape 1, image 1 de 2 Asus U56E Laptop Screen Replacement, Screen: étape 1, image 2 de 2
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: étape 2, image 1 de 3 Asus U56E Laptop Screen Replacement: étape 2, image 2 de 3 Asus U56E Laptop Screen Replacement: étape 2, image 3 de 3
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: étape 3, image 1 de 3 Asus U56E Laptop Screen Replacement: étape 3, image 2 de 3 Asus U56E Laptop Screen Replacement: étape 3, image 3 de 3
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: étape 4, image 1 de 2 Asus U56E Laptop Screen Replacement: étape 4, image 2 de 2
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: étape 5, image 1 de 1
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: étape 6, image 1 de 2 Asus U56E Laptop Screen Replacement: étape 6, image 2 de 2
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: étape 7, image 1 de 2 Asus U56E Laptop Screen Replacement: étape 7, image 2 de 2
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: étape 8, image 1 de 2 Asus U56E Laptop Screen Replacement: étape 8, image 2 de 2
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: étape 9, image 1 de 3 Asus U56E Laptop Screen Replacement: étape 9, image 2 de 3 Asus U56E Laptop Screen Replacement: étape 9, image 3 de 3
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: étape 10, image 1 de 2 Asus U56E Laptop Screen Replacement: étape 10, image 2 de 2
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: étape 11, image 1 de 3 Asus U56E Laptop Screen Replacement: étape 11, image 2 de 3 Asus U56E Laptop Screen Replacement: étape 11, image 3 de 3
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: étape 12, image 1 de 1
    • The screen can now be safely removed from the laptop.
David Zilar
Membre depuis le 09/29/15
167 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-5, Green Fall 2015 Membre de l'équipe Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,413
