Asus Z54C-JS31 Keyboard Replacement
Introduction
Passez à l'étape 1When a keyboard no longer functions correctly it is necessary to replace it to regain proper function.
Ce dont vous avez besoin
Outils
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
Turn the laptop to its normal position and open the display to show the keyboard.
Gently push back the five tabs holding the keyboard down using the plastic opening tool.
