Aller au contenu principal
BLU Advance 4.0 Screen Replacement
Ce dont vous avez besoin
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: étape 1, image 1 de 2 BLU Advance 4.0 Screen Replacement, Removing the back cover: étape 1, image 2 de 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: étape 2, image 1 de 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: étape 2, image 2 de 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: étape 2, image 3 de 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: étape 3, image 1 de 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Screen Replacement, Screen: étape 4, image 1 de 2 BLU Advance 4.0 Screen Replacement, Screen: étape 4, image 2 de 2
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
  5. BLU Advance 4.0 Screen Replacement: étape 5, image 1 de 2 BLU Advance 4.0 Screen Replacement: étape 5, image 2 de 2
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: étape 6, image 1 de 1
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
Jon Sclar
Membre depuis le 11/13/14
292 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 27
30 derniers jours : 33
Total : 3,880
