Aller au contenu principal
BLU Grand M2 Rear Camera Replacement
Ce dont vous avez besoin
  1. BLU Grand M2 Rear Camera Replacement, Confirm the Device: étape 1, image 1 de 2 BLU Grand M2 Rear Camera Replacement, Confirm the Device: étape 1, image 2 de 2
    • Check the front panel and confirm you are repairing the BLU Grand M2 (figure 1)
    • Turn the device over and identify the the rear-facing camera (figure 2) This is what you will be replacing
  2. BLU Grand M2 Rear Camera Replacement: étape 2, image 1 de 1
    • Locate the two torx screws at the bottom of the phone and remove them using the T2 Torx Screwdriver.
  3. BLU Grand M2 Rear Camera Replacement: étape 3, image 1 de 1
    • Use the suction and pry tools to carefully remove the black plate.
    • Be cautious!! Do not damage the phone display or inside components while using pry and suction tools.
  4. BLU Grand M2 Rear Camera Replacement: étape 4, image 1 de 1
    • Identify the back-panel camera in the left -hand corner of the open device. (Figure 1)
  5. BLU Grand M2 Rear Camera Replacement: étape 5, image 1 de 3 BLU Grand M2 Rear Camera Replacement: étape 5, image 2 de 3 BLU Grand M2 Rear Camera Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the Plastic Pry Tool to carefully to lift the tab on the right-hand side of the connector.
    • Carefully remove camera from housing using a pair of tweezers.
Alan Rodriguez
Membre depuis le 09/10/18
311 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team S1-G3, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 427
