Aller au contenu principal
BLU Life X8 Screen Replacement
Alexander Prasil
Alexander Prasil et 3 autres contributeurs
Dernière mise à jour le December 13, 2017
30 minutes
Difficile
If the touch screen or haptic feedback isn't working, the screen may need to be replaced. This guide will explain how to remove and replace the screen of your BLU Life X8.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. BLU Life X8 Screen Replacement, Battery: étape 1, image 1 de 2 BLU Life X8 Screen Replacement, Battery: étape 1, image 2 de 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Screen Replacement: étape 2, image 1 de 1
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Screen Replacement: étape 3, image 1 de 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Screen Replacement, Motherboard: étape 4, image 1 de 2 BLU Life X8 Screen Replacement, Motherboard: étape 4, image 2 de 2
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Screen Replacement: étape 5, image 1 de 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Screen Replacement: étape 6, image 1 de 1
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Screen Replacement: étape 7, image 1 de 2 BLU Life X8 Screen Replacement: étape 7, image 2 de 2
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Screen Replacement: étape 8, image 1 de 3 BLU Life X8 Screen Replacement: étape 8, image 2 de 3 BLU Life X8 Screen Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Screen Replacement: étape 9, image 1 de 1
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Screen Replacement: étape 10, image 1 de 1
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Screen Replacement, Daughterboard: étape 11, image 1 de 1
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Screen Replacement: étape 12, image 1 de 1
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Screen Replacement: étape 13, image 1 de 3 BLU Life X8 Screen Replacement: étape 13, image 2 de 3 BLU Life X8 Screen Replacement: étape 13, image 3 de 3
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Screen Replacement: étape 14, image 1 de 1
    • Lift the daughterboard from the frame using the plastic opening tool.
  15. BLU Life X8 Screen Replacement, Screen: étape 15, image 1 de 1
    • Take off the sticker and the ribbon cables glued to the back of the screen.
Alexander Prasil
Membre depuis le 09/28/17
546 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 468
