Aller au contenu principal
BLU R2 Plus Front-Facing Camera Replacement
Derek Thomas
Derek Thomas et 2 autres contributeurs
Dernière mise à jour le May 16, 2024
45 minutes - 1 heure
Modérée
Tutoriel réalisé par la communauté
Replace your broken or nonfunctional front-facing camera with this guide. The plastic plates covering both the motherboard and the daughterboard each have skinny and fragile arms on them. Be careful not to break them.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. BLU R2 Plus Front-Facing Camera Replacement, Power Off: étape 1, image 1 de 1
    • Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
  2. BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: étape 2, image 1 de 3 BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: étape 2, image 2 de 3 BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: étape 2, image 3 de 3
    • Insert your pick in the top left-hand corner where the little indent is.
    • Slide the pick all the way around the phone until the back cover is loose and ready to be released.
  3. BLU R2 Plus Front-Facing Camera Replacement, Remove the Back Cover: étape 3, image 1 de 1
    • Remove the back cover and set it aside.
  4. BLU R2 Plus Front-Facing Camera Replacement, Reveal the Screws: étape 4, image 1 de 2 BLU R2 Plus Front-Facing Camera Replacement, Reveal the Screws: étape 4, image 2 de 2
    • On both sides of the battery, use an opening pick to peel up the edge of the sticker covering the battery shield in order to expose the screws securing the plastic plating.
  5. BLU R2 Plus Front-Facing Camera Replacement, Tape the sticker: étape 5, image 1 de 1
    • Use tape to hold back the battery sticker so it's easier to unscrew the plates.
  6. BLU R2 Plus Front-Facing Camera Replacement, Unscrew Upper Plastic Plate: étape 6, image 1 de 2 BLU R2 Plus Front-Facing Camera Replacement, Unscrew Upper Plastic Plate: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 screwdriver to remove the 9 screws from the upper plastic plate.
    • Use a magnetic mat to organize your screws and prevent you from losing them.
  7. BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: étape 7, image 1 de 3 BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: étape 7, image 2 de 3 BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: étape 7, image 3 de 3
    • Use an opening pick to unclip the upper plastic plate from the phone.
    • Once unclipped, slide it up and out of the phone.
    • Be careful not to break the small arms of the plate upon removal.
  8. BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: étape 8, image 1 de 3 BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: étape 8, image 2 de 3 BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: étape 8, image 3 de 3
    • Use a spudger to unclip the ribbon cable from the motherboard/logic board. Carefully use blunt tweezers or angled tweezers to pull the ribbon cable out of the socket. Then use the tweezers to wiggle the camera out of its socket.
    • Be very careful not to break the ribbon cable as it's very fragile. This doesn't really matter if you're taking the camera out as it's already broken.
Derek Thomas
Membre depuis le 09/02/21
772 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 50
