BLU Tank II Keypad Replacement
Introduction
Passez à l'étape 1This guide will demonstrate how to remove and replace the keypad for the BLU Tank II cell phone. You will need to remove the parts talked about in the previous guides in order to replace the keypad. You will also need a screwdriver and an opening tool to replace the keypad.
Ce dont vous avez besoin
With the screen facing you, find the left corner of the phone. There should be a visible groove.
With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
Lift the battery up and carefully remove the battery.
Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
Peel the keypad out from the keyholes in the front plate.
