Aller au contenu principal
Benchmade Griptillian Disassembly
Spin Modder
Spin Modder et 2 autres contributeurs
Dernière mise à jour le October 15, 2024
3 - 10 minutes
Très facile
Puces !
Tutoriel réalisé par la communauté
How to disassemble your Benchmade Griptillian
Ce dont vous avez besoin
  1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: étape 1, image 1 de 1
    • Be sure to make note of what side the belt clip is on for reassembly.
  2. Benchmade Griptillian Disassembly, Remove screws: étape 2, image 1 de 1
    • Use a T6 bit to remove the two screws holding the belt clip.
  3. Benchmade Griptillian Disassembly, Remove T6 Screws: étape 3, image 1 de 1
    • Use the T6 bit to remove the four screws holding the handle in place.
  4. Benchmade Griptillian Disassembly, Turn the knife over: étape 4, image 1 de 1
    • Turn the knife over and remove one T6 screw.
  5. Benchmade Griptillian Disassembly, Remove the T8 screw: étape 5, image 1 de 1
    • Turn the knife over and remove the T8 screw that is going through the hinge.
  6. Benchmade Griptillian Disassembly, Remove the handle: étape 6, image 1 de 1
    • Once you've removed the screw, you can remove the handle.
  7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: étape 7, image 1 de 1
    • Using the T6 bit, drive the hinge pin out of the other handle.
  8. Benchmade Griptillian Disassembly, Remove the other handle: étape 8, image 1 de 1
    • Once you've done this you can remove the other handle.
  9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: étape 9, image 1 de 1
    • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
  10. Benchmade Griptillian Disassembly, Sand both sides of copper: étape 10, image 1 de 1
    • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
  11. Benchmade Griptillian Disassembly, Reverse process to re assemble: étape 11, image 1 de 1
    • Reverse process to re assemble.
3 autres ont terminé cette réparation.
Spin Modder
Membre depuis le 07/21/22
256 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 23
Total : 614
