Bissell Air180 Control Buttons Replacement
Introduction
Passez à l'étape 1The control buttons on the Bissell Air180 can be found along the top of the device on the same panel as the upper vent screen. These buttons can often malfunction, where one or more of them aren't working properly or they aren't properly responding to commands.
Ce dont vous avez besoin
Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
Pry off the top vent, separating it from the fan and motherboard housing.
