Aller au contenu principal
Bissell Air180 Power Supply Replacement
Aleah Ramos
Aleah Ramos et 2 autres contributeurs
Dernière mise à jour le December 19, 2022
5 minutes
Modérée
The power supply on the Bissell Air180 is the housing on the bottom half of the device housing the air filter. Through this housing, the power cord that is plugged into the wall sends power through the device. Removing the power supply will allow you to replace the entire power supply housing or replace the power cord.
Ce dont vous avez besoin
Outils
  1. Bissell Air180 Power Supply Replacement, Air Filter: étape 1, image 1 de 2 Bissell Air180 Power Supply Replacement, Air Filter: étape 1, image 2 de 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Power Supply Replacement: étape 2, image 1 de 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Power Supply Replacement: étape 3, image 1 de 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Power Supply Replacement, Power Supply: étape 4, image 1 de 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Power Supply Replacement: étape 5, image 1 de 3 Bissell Air180 Power Supply Replacement: étape 5, image 2 de 3 Bissell Air180 Power Supply Replacement: étape 5, image 3 de 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
Aleah Ramos
Membre depuis le 10/26/22
533 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Membre de l'équipe UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 119
