Aller au contenu principal
Black and Decker Pivot MAX Power Switch Replacement
Avery Hanulcik
Avery Hanulcik et 4 autres contributeurs
Dernière mise à jour le August 16, 2021
15 minutes
Modérée
Photos d’action
Nécessite plus d'images
The power switch on the Black and Decker Pivot MAX turns the appliance on when connected to power. If your Black and Decker Pivot MAX will not turn on, is stuck on, or has a finicky power switch, replacing this component is something you should consider.
This guide will take you through the steps of removing and re-assembling key components of the Black and Decker Pivot MAX to allow you to replace the power switch. Tools you will need for this project will be a Phillips head screwdriver and a soldering iron.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: étape 1, image 1 de 2 Black and Decker Pivot MAX Power Switch Replacement, Battery: étape 1, image 2 de 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: étape 2, image 1 de 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: étape 3, image 1 de 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: étape 4, image 1 de 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: étape 5, image 1 de 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: étape 6, image 1 de 1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: étape 7, image 1 de 1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: étape 8, image 1 de 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: étape 8, image 2 de 3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: étape 8, image 3 de 3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: étape 9, image 1 de 2 Black and Decker Pivot MAX Power Switch Replacement: étape 9, image 2 de 2
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 1,041
