Aller au contenu principal
Black and Decker TR1278B Bread Grabber Spring Replacement
Brea-Monique
Brea-Monique et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
Aucune estimation
Modérée
Photos d’action
Nécessite plus d'images
This is a replacement guide for the bread grabber springs on the Black and Decker TR1278B.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Black and Decker TR1278B Bread Grabber Spring Replacement, Top Cover: étape 1, image 1 de 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 2, image 1 de 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 3, image 1 de 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 4, image 1 de 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 5, image 1 de 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Bread Grabber Spring Replacement, Bread Grabber Spring: étape 6, image 1 de 1
    • Locate the spring
  7. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 7, image 1 de 1
    • Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
    • Use metal spudger to loosen clamps on spring.
  8. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • Use needle nose tweezers to pull the spring off of its hook.
    • Repeat this step for the opposite side.
  9. Black and Decker TR1278B Bread Grabber Spring Replacement: étape 9, image 1 de 1
    • Remove the old spring from the toaster unit to insert the new one.
Brea-Monique
Membre depuis le 02/15/17
399 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 8-1, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 1,371
