Black and Decker TR1278B Lever Catch-Spring Replacement
Introduction
Passez à l'étape 1Black and Decker TR1278B toaster lever catch-spring replacement guide.
Ce dont vous avez besoin
Outils
Afficher plus…
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
Hi there, thanks for this guide. I have a little issue : one of the screws is quite unusual, probably because it’s not meant to be repaired by a poor peasant. It has a little pin in it and I can’t unscrew it with the tools I have. Any tips ?
