Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Blueair 311 Auto: Disassembly and disconnection of ionizer
Ce dont vous avez besoin
    1. Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove the top fan housing from the base: étape 1, image 1 de 1
      • Unplug the power adapter of the air filter
      • Grab the top (white) housing, rotate it counter-clockwise, and lift it to detach it from the base.
      Demander à FixBot
      Ajouter un commentaire
    2. Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove screws: étape 2, image 1 de 2 Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove screws: étape 2, image 2 de 2
      • Rotate the filter top to be upside down.
      • Remove the 4 phillips head screws (red)
      • Remove the 4 phillips head screws (blue). These screws need a long/skinny screwdriver to reach, as they are sunk into plastic holes. But, they seem to be the same screws as the red screws.
      • Optionally, you can remove the 1 screw holding on the LED for the indicator on the front, and the plastic tab for the (presumably) particle sensing, but it is easier to reassemble if you do not remove those fasteners.
      Demander à FixBot
    3. Blueair 311 Auto: Disassembly and disconnection of ionizer, Lift the black top from the white housing: étape 3, image 1 de 1
      • Lift the black top from the white housing. Lift from the side where the white clips are.
      Demander à FixBot
    4. Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: étape 4, image 1 de 3 Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: étape 4, image 2 de 3 Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: étape 4, image 3 de 3
      • Unclip the connector for the 2-wire ionizer power cable, and disconnect if from the printed circuit board (PCB)
      • Note: It is possible & easier to unclip the connector, without fully removing the PCB, i.e. by reaching behind the PCB, and applying pressure purely by the feeling of the clip, to unclip it. These photos are just for clarity.
      Demander à FixBot
2 autres ont terminé cette réparation.
photocyte
Membre depuis le 07/02/20
136 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 25
30 derniers jours : 138
Total : 5,188
