Aller au contenu principal
Bose Solo 5 Sound Bar Indicator Light Replacement
Emma
Emma et 6 autres contributeurs
Dernière mise à jour le January 4, 2021
30 minutes - 1 heure
Modérée
Étapes manquantes
This is a step-by-step guide to replacing the indicator light on a Bose Solo 5 Sound Bar (Model # 732522-1110). The Indicator light on this speaker will show when the system is on, and shows the status of the system when in operation. The repair process is classified as a moderate difficulty, and does not require any specialized skills.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Bose Solo 5 Sound Bar Indicator Light Replacement, Indicator Light: étape 1, image 1 de 1
    • Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
  2. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 2, image 1 de 1
    • Remove five 18.25mm screws with a Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 3, image 1 de 1
    • Gently remove the gold plates and the snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 4, image 1 de 1
    • Using the plastic opening tool, slightly lift the circuit board up and remove it from the housing.
  5. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 5, image 1 de 1
    • Disconnect the cords running to the white connector by pulling upon the tab until it is disconnected completely.
  6. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 6, image 1 de 1
    • Locate the two clear LED receptors and note that one has two prongs and the other has three prongs.
  7. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 7, image 1 de 2 Bose Solo 5 Sound Bar Indicator Light Replacement: étape 7, image 2 de 2
    • Locate on the back of the control panel where it states LED 902, 903, 904, and 905.
  8. Bose Solo 5 Sound Bar Indicator Light Replacement: étape 8, image 1 de 2 Bose Solo 5 Sound Bar Indicator Light Replacement: étape 8, image 2 de 2
    • If there is any debris located in these locations, use the spudger tool to thoroughly clean the area.
To reassemble the sound bar, follow the steps listed above in reverse order.
Emma
Membre depuis le 10/05/18
500 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G7, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G7
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 27
Total : 5,789
