Brother CS6000i Needle Plate Replacement
Introduction
Passez à l'étape 1This guide will teach you how to replace the metal needle plate on the Brother CS6000i. You will need a Phillips #2 screwdriver as well as a 4mm flathead screwdriver. It will take about 15-20 minutes.
Ce dont vous avez besoin
Outils
Remove the five 20 mm Phillips #2 screws on the back of the device.
Remove the single 28 mm Phillips #2 screw on the back of the device.
Remove the single 23 mm Phillips #2 screw on the back of the device.
Remove the two screws securing the needle plate with a 4mm flathead screwdriver.
