Canon PowerShot ELPH 310 HS Lens Replacement
Introduction
Passez à l'étape 1The Cannon PowerShot ELPH 310 HS may experience problems with the lens. The lens may be stuck inside the camera, or will not retract back into the camera. This guide is to assist in the replacement of the lens.
Ce dont vous avez besoin
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
On the front motherboard, unscrew the one bottom right 3 mm Phillips head screw.
4 autres ont terminé cette réparation.
1 commentaire de tutoriel
excellent procedure. nice pix too. hint about those fragile flex cables is important, they are thinner than a human hair!
