Aller au contenu principal
Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement
Michelle Ngo
Michelle Ngo et 5 autres contributeurs
Dernière mise à jour le September 8, 2022
8 minutes
Modérée
Photos d’action
A besoin de meilleures images
If you’re experiencing problems with your screen, consider reading this guide. This guide will show you how to replace the LCD screen in your Canon PowerShot ELPH 330 HS.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: étape 1, image 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: étape 1, image 2 de 2
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 2, image 1 de 1
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 3, image 1 de 1
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 4, image 1 de 1
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 5, image 1 de 1
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 6, image 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 6, image 2 de 2
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 7, image 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 7, image 2 de 2
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: étape 8, image 1 de 1
    • Using the spudger, carefully pry the top to remove the LCD screen.
Michelle Ngo
Membre depuis le 07/23/19
595 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membre de l'équipe UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 membres
3 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 37
Total : 644
