Aller au contenu principal
Canon PowerShot ELPH330 HS Camera Case Replacement
Michelle Ngo
Michelle Ngo et 3 autres contributeurs
Dernière mise à jour le September 18, 2019
2 - 5 minutes
Modérée
Photos d’action
Détails manquants
Is your camera case cracked or broken? Are there dust particles and dirt getting into your camera? You may want to consider replacing the case of your camera if the symptoms mentioned above are present.
Before starting your replacement for the canon case, make sure to be in a space that is dust-free and very open. During this replacement, there will be many small screws used.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: étape 1, image 1 de 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: étape 1, image 2 de 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 2, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 3, image 1 de 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 4, image 1 de 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: étape 5, image 1 de 1
    • Using your fingers, carefully pry the case apart at the seam.
Michelle Ngo
Membre depuis le 07/23/19
595 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membre de l'équipe UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 216
