Aller au contenu principal
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
Michelle Ngo
Michelle Ngo et 4 autres contributeurs
Dernière mise à jour le January 17, 2025
30 - 50 minutes
Modérée
Photos d’action
A besoin de meilleures images
Détails manquants
If you’re experiencing problems with your camera turning on or the camera taking photos, consider replacing the power/shutter button panel on your Canon PowerShot ELPH330 HS camera. This guide will show you how to replace your damaged power button.
Before you begin, make sure that your camera is turned off and you remove the battery.
Ce dont vous avez besoin
Pièces
Outils
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  • Phillips #000 Screwdriver
Afficher plus…
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: étape 1, image 1 de 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: étape 1, image 2 de 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 2, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 3, image 1 de 1
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 4, image 1 de 1
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 5, image 1 de 1
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 6, image 1 de 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 6, image 2 de 2
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 7, image 1 de 1
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: étape 8, image 1 de 1
    • Lift the panel off from the top of the camera with your hands.
Michelle Ngo
Membre depuis le 07/23/19
595 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G3, Liner Summer 2019 Membre de l'équipe UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 399
