Canon PowerShot G1 X Back Camera Casing Replacement
Introduction
Passez à l'étape 1To reassemble the device follow these steps in reverse order.
Ce dont vous avez besoin
Pull the switch on the back of the battery case back towards the open arrow to release a latch.
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
