Aller au contenu principal
Canon PowerShot G11 Rear Cover Replacement
Dustin Brinegar
Dustin Brinegar et 2 autres contributeurs
Dernière mise à jour le May 7, 2024
10 - 15 minutes
Facile
Turning off the camera, removing the battery, and removing the memory card. Unplugging the camera from any device it is hooked up to.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: étape 1, image 1 de 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Cover Replacement: étape 2, image 1 de 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Cover Replacement: étape 3, image 1 de 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Cover Replacement: étape 4, image 1 de 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Cover Replacement: étape 5, image 1 de 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Cover Replacement: étape 6, image 1 de 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Cover Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Cover Replacement: étape 8, image 1 de 1
    • The rear cover is now unattached from the camera.
Dustin Brinegar
Membre depuis le 01/21/15
688 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-6, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,124
