Aller au contenu principal
Canon PowerShot G12 LCD Screen Replacement
Nathan Meuwissen
Nathan Meuwissen et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
20 - 30 minutes
Difficile
Replacing the LCD screen is a highly-invasive, step-intensive process that becomes necessary if the screen has sustained damage to due a crack, water, or an otherwise internal malfunction.
In this guide, you will learn how to replace the LCD screen carefully.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Canon PowerShot G12 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Open the LCD screen from its locked position so the screen is visible.
  2. Canon PowerShot G12 LCD Screen Replacement: étape 2, image 1 de 1
    • Flip the LCD screen perpendicular to the camera exposing the side screws.
    • Using a Phillips-head 00 screwdriver, unscrew the screws on both sides of the LCD screen.
  3. Canon PowerShot G12 LCD Screen Replacement: étape 3, image 1 de 1
    • Remove the front plate which states the Canon brand by prying open the side farthest from the camera simply with your fingers.
    • The circuit and internal wires will be exposed.
  4. Canon PowerShot G12 LCD Screen Replacement: étape 4, image 1 de 1
    • Flip the LCD screen vertically and remove the final screws on the outer edge of the screen with the same Phillips-head 00 screwdriver. All screws have Loctite (blue) on them so they a difficult to turn. Make sure your Phillips screw driver fits perfectly. Sometimes a new screwdriver will need to have the tip filed down a little to fit.
    • The internal mechanisms will become loose and be able to be taken out.
  5. Canon PowerShot G12 LCD Screen Replacement: étape 5, image 1 de 1
    • Using a spudger, remove the external shell of the LCD screen leaving only the metal internal circuit board and screen attached.
  6. Canon PowerShot G12 LCD Screen Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Using a pair of precision tweezers, carefully remove the yellow circuit connector from the port on the green circuit board.
    • Pull the yellow circuit connector down removing the screen from the metal shell.
  7. Canon PowerShot G12 LCD Screen Replacement: étape 7, image 1 de 1
    • Place the new LCD screen into the metal shell with the yellow connector tab facing outward.
    • Connect the new screen with the green circuit board ensuring you use the tweezers to connect it fully into the port.
3 autres ont terminé cette réparation.
Nathan Meuwissen
Membre depuis le 02/23/15
550 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Leahy Winter 2015 Membre de l'équipe USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 membres
6 tutoriels rédigés
2 commentaires
ATTENTION
Connector of cable between camera and lcd board can be fit up or down side
Mark it before disconnect
Dufour - Réponse
Hello!
I wanted to change the screen but it seems that camera screen differ from each other according to the country where you bought it has anyone any piece of advice ?
I bought it in Singapore but live in Europe and I’m afraid to waist money buying a European one!
Chloe a - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 22
30 derniers jours : 69
Total : 8,348
